Date/Time: Tue, 30 Apr 2024 05:44:52 +0000
Time and sales
View Count: 1300
[2013-10-28 08:25:24] |
TradingMarketProfile - Posts: 120 |
Hello, I would like to know if it's possible to highlight quantities at bid and at ask (see picture) And if it's possible to add an option to set the configuration by default Thanks Date Time Of Last Edit: 2013-10-28 09:23:45
[2013-10-28 22:15:03] |
Hello, nobody to answer that question ? |
[2013-10-29 00:42:44] |
Highlighting is supported. Refer to the documentation here for this: http://www.sierrachart.com/index.php?l=doc/doc_TimeandSalesWindow.html We have just updated the highlighting documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-29 00:42:58
[2013-10-30 10:18:46] |
not on the way i would like.. the highlight by field (see picture) will be ok but one color for bid and one different for ask So maybe it's possible to add this option Thanks |
Attachment Deleted. |
[2013-10-30 17:06:50] |
User14266 - Posts: 225 |
I think this is a great request. I am unable to use the highlight feature, because I can not differentiate between bid and ask based on color. |
