Date/Time: Sat, 04 May 2024 22:50:32 +0000
Using TD AMeritrade to trade the ES futures
View Count: 1080
[2018-10-03 03:50:43] |
User183691 - Posts: 3 |
New subscriber and need a data feed to run real time TPO charts on Sierra Charts for S&P E-mini Futures? I have TD Ameritrade, and understand their API is not supported. Very confused with all the different options for data feeds. Do I need Market Depth? Should I open up an Interactive Brokers account? What is my best option for trading Futures? |
[2018-10-03 04:49:07] |
You do not need market depth data. Did you want just simply the real-time data feed or did you want to trade as well from Sierra Chart?
[2018-10-03 05:15:31] |
First priority is the the real time data feed of the ES e-mini futures. - I can trade futures on TD Ameritrade for now. - Do I need to pay for a connection service as well as a Exchange service? In the future maybe I can look into trading on the SC Platform. - If so, would I need a different broker? Thanks for you help! |
[2018-10-03 18:04:05] |
You will need to pay for the Sierra Chart Exchange Data Feed and the CME exchange fee to access the real-time futures data. Follow the setup instructions here: Sierra Chart Exchange Data Feed: Setup Instructions In the future maybe I can look into trading on the SC Platform. - If so, would I need a different broker? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
