Date/Time: Tue, 07 May 2024 04:22:14 +0000
Log in 2 computer at same time
View Count: 554
[2018-10-02 14:59:06] |
User123003 - Posts: 29 |
Hi, I know that I can log in 2 computers at same time, which I used to do that, but now when I log into 2nd computer, it didn't work. It will log in one computer, then log out, then log in to the other one, then log out, back and forth, so please help solve this problems. Thank you, |
[2018-10-02 18:50:10] |
You need to contact your Trading service about this. What is happening is you are getting disconnected from their service. This is totally unrelated to Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-02 18:50:32
