Date/Time: Thu, 02 May 2024 09:49:19 +0000
[User Discussion] - UniRenko chart or FlexiRenko
View Count: 4019
[2018-10-02 08:44:05] |
User162290 - Posts: 11 |
Hi , Do any of you guys know how to create UniRenko or FlexiRenko bars ... there is an image on this link to show what i mean ? https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=13764 cheers Thanks tradingkevin |
[2018-10-02 18:40:00] |
Refer to the documentation for this here: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html#FlexRenko Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-02 21:21:29] |
Xfanman1 - Posts: 320 |
Kevin, that looks like one of my older Charts. If you need the specific settings for the current SC Renko implementation, this is what I'm currently using to mimic the NT Renko implementation. See the attached images for the settings. -- Scott |
Renko Settings.PNG / V - Attached On 2018-10-02 21:21:22 UTC - Size: 406.85 KB - 1174 views |
[2018-10-03 07:23:30] |
man those are beautiful settings Scott..what a clean looking chart with nice swings an pivots.. thanks a lot. I will use it to see the overall swings i the market...it's amazing how every 6 months there is a new thing that is invented and we thought all was already invented.... you had candles then volume profile then bookmap for order book then renko then flexirenko ..etc... etc... it's amazing..my favorite is still candles but flexirenko is great for nice clean chart... cheers Scott..you Rock like a Renko bot !!! : ) jijij tradingkevin aka Gk aka ZovniA aka Kevin |
[2018-11-06 08:11:27] |
User371906 - Posts: 141 |
Hello, Could you tell me how to set up this cloud? Thank You Regards g |
[2018-11-06 08:46:24] |
set up this cloud???? what do you mean ?? this cloud ?
[2018-11-06 09:23:22] |
Please take a look at attached picture. Ichimoku cloud?
Date Time Of Last Edit: 2018-11-06 09:23:53
cloud renko.JPG / V - Attached On 2018-11-06 09:22:48 UTC - Size: 239.21 KB - 819 views |
[2018-11-06 12:04:41] |
you have to contact Xfanman directly... it's his stuff cheers |
[2018-11-06 13:33:46] |
That’s not the Ichimoku cloud, it’s simply 2 moving averages with a color fill in between. You can do the same thing by selecting Fill Top and Fill Bottom on the Moving Averages and selection whatever colors you wish in the study. I’m aaay from a PC at the moment but if you need specific settings I can post them later. Scott |
[2018-11-06 13:54:52] |
Scott, Thank you for reply, If you could post them or send by PM would be appreciative of this. Regards g |
[2018-11-06 16:11:29] |
G, Simply add the Study Flexible MA from the Add Custom Study button then select it in the User Contributed Studies I've attached 2 images that show it in the Study Settings Window. Select your MA's and for each one select the Color Fill you want using Fill Top Down and Fill Bottom Up. You should get results similar to mine. If not let me know. -- Scott |
Flexible MA.PNG / V - Attached On 2018-11-06 16:11:17 UTC - Size: 35.45 KB - 771 views Flexible MA2.PNG / V - Attached On 2018-11-06 16:11:23 UTC - Size: 50.59 KB - 678 views |
[2018-11-06 18:16:42] |
Scott & 371906, Thank You |
[2019-10-04 21:19:18] |
User877755 - Posts: 1 |
Hi, I know this post is a little old, but I wanted to give it a try, could you please share this chart with me? Thanks Alex |
[2022-02-01 13:55:44] |
User92573 - Posts: 483 |
Hi Scott Was there ever a uni-renko study written? PS did you ever reply to my PM? Many thanks |
[2022-02-01 14:06:16] |
Can I also ask what the Blue/Red study running behind the stoch is? Many thanks |
