Date/Time: Sat, 04 May 2024 10:32:50 +0000
Enable Futures CME Live Data: Have a Funded Account
View Count: 951
[2018-10-01 18:35:28] |
User226793 - Posts: 160 |
Folks, I need your help to enable a futures live data for Sierra Charts.. I have a futures account with Ninja Trader. Can someone please let me know what I need to do to enable the CME Data? If you can call me for a min at * that would be helpful...
Date Time Of Last Edit: 2018-10-01 22:23:03
[2018-10-02 19:05:50] |
Folks, would appreciate your help with regards to the question
[2018-10-02 19:19:58] |
Yes we apologize for the delay with this. It is that there is so much complexity with the subject, that sometimes this gets delayed. Now did you want to use the Sierra Chart provided CME data feed or use the one that you get through CQG or Rithmic with ninja trader? Here is the information about the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php One question we had is whether you want to use ninja trader still for trading? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-02 19:22:28
[2018-10-02 21:20:15] |
I just want the Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts.. Now do I need to have a user and password from Ninja Trader for me to have this? As they charge me $25 for a login... If no could someone please enable this for me? I believe its $15/ month right?
[2018-10-02 22:19:06] |
You would need to be able to connect Sierra Chart once a month to your ninja trader trading account through CQG or Rithmic to get the lower cost CME fees. And for the cost of the data feed, refer to the section here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-03 14:53:24] |
Thanks for your response, when you say connect once a month, I presume I have to connect through CQG and connect with the User and Password they provide?
[2018-10-03 15:28:47] |
Folks, thanks.. Can someone just give me a quick call at 646 467 2630 so that I can go ahead and buy the CME data package? Much appreciate your help
[2018-10-03 16:48:29] |
Folks, I understand you guys are busy can someone call me based on the above number or send me the direct link for me to buy the CME Bundle for Sierra which is $15/ Month
[2018-10-03 17:10:14] |
You need to follow the step-by-step instructions here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Thanks for your response, when you say connect once a month, I presume I have to connect through CQG and connect with the User and Password they provide? Yes.If you require remote assistance support that is available at $0.65 per minute. Let us know if you want to proceed. But we think it is best just for you to follow through the step-by-step instructions and if you have trouble with a particular step just let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-03 18:18:03
[2018-10-04 15:24:39] |
I trade the EQ, NQ and CL. What Set the Number of Real-Time Symbols Per Connection option should I choose?
[2018-10-04 16:07:54] |
You will just need the 20 symbol option. That is sufficient.
