Date/Time: Fri, 03 May 2024 21:44:17 +0000
Historical FOP data
View Count: 517
[2018-10-01 14:20:37] |
User754985 - Posts: 109 |
Hi, I understand from docs that SC maintains historical intraday FOP data for CME futures as from Sept (or Nov) of 2017. Is (best)bid-ask available with 1min resolution or is it only "trade"? Is tick data maintained, and if yes, will it contain bid-ask? Thank you. |
[2018-10-01 18:58:36] |
Yes this data is available and it is tick by tick. And it does contain the bid and ask prices at the time of the trade.
[2018-10-01 19:33:19] |
Sorry, I am not fully clear. Is bid-ask available with 1 min bars or is it only for tick data? What is meant by "bid-ask at the time of the trade"? Often there are no Trades, but there is bid and ask..I assume these would be available regardless of a trade occuring, correct? |
[2018-10-02 18:56:43] |
Is bid-ask available with 1 min bars or is it only for tick data? Only the bid and ask prices are recorded when there is a trade. We tried recording them all the time but it created a major performance issue. But if you have real-time access to this data feed, you can record them on your side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-02 18:57:14
[2018-10-02 19:16:25] |
Understand. However, option trades occur infrequently, rendering such data "outdated" for backtesting. Would you consider switching to a less frequent, 1/min recording of bid-ask instead? This would keep load appr. the same, but data would be usable.. |
[2018-10-07 14:06:02] |
bump
[2018-10-07 22:38:59] |
We are we are fully declining further comment here. We do not have to say that. If you do not hear from us. It means we are declining this.
