Date/Time: Tue, 07 May 2024 16:10:53 +0000
[User Discussion] - Same Data provider different depth totals
View Count: 508
[2018-09-30 23:43:25] |
User536237 - Posts: 2 |
Hey, Both a friend and I are connected to CQG. We both had different bid/ask totals. Why is that? Eventually it smoothed out a little, but was 500-700 off at times. |
Private File |
[2018-10-11 13:25:57] |
anything?
[2018-10-11 18:19:51] |
There is quite a lot of work to analyze this and this is not something we would do for an external data feed. This is why we marked it as a User Discussion. One thing about the CQG data feed, is that the market depth data is time stamped to the local computer clock so it is hypersensitive to that which can contribute to a problem like this. Our recommendation is to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-11 18:20:26
