Date/Time: Fri, 03 May 2024 12:32:03 +0000
Message Log
View Count: 535
[2018-09-28 17:07:53] |
infpz - Posts: 826 |
Any ideas what caused this? Warning: 101 Fonts have been allocated, I 2018-09-28 09:25:30 • |
[2018-09-28 17:46:34] |
What version are you seeing this on? It would seem to be a problem because 101 unique fonts would be very unlikely.
[2018-09-28 17:54:03] |
It was 1809 and then again on 1812 Pre-release.
[2018-09-28 18:49:32] |
We looked into this some more, and that number of fonts would not necessarily be unusual if you are using the automatic font size feature in either Numbers Bars, TPO Profile Charts, or the Volume by Price studies. Unless you are noticing any performance issue, just disregard the message and we will remove the word Warning from it so it does not look serious. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-28 18:49:53
