Date/Time: Mon, 20 May 2024 00:36:44 +0000
Different values
View Count: 567
[2018-09-28 13:01:48] |
nicktrader - Posts: 665 |
I am using the studies - TPO - TPO Value Area Lines I do get different values concerning POC and VAH/ VAL. What is the problem? |
TPO vs TPO Lines.png / V - Attached On 2018-09-28 12:59:42 UTC - Size: 48.55 KB - 219 views |
[2018-09-28 13:57:58] |
I got it. If you use a M3 or othrt TF, you get different values. How can I avoid this result? I'd like to see the "origin" values.
[2018-09-28 18:10:09] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#IncorrectValues Make sure in the Chart >>Chart Settings you have also enabled New Bar at Session Start. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-01 08:50:54] |
As I could see you fixed the problem with different values in different TF. A small difference still exists (see pic).
TPO ValueAreaL.png / V - Attached On 2018-10-01 08:49:55 UTC - Size: 37.45 KB - 224 views |
[2018-10-01 18:12:52] |
If you want us to look into this, it is chargeable at 50 USD per hour. And we would need to look at your Chartbook. The time estimate we expect would be less than 20 minutes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-01 18:13:05
