Date/Time: Thu, 16 May 2024 18:35:44 +0000
Cash $SPX No Intraday
View Count: 909
[2018-09-27 16:08:02] |
User821671 - Posts: 10 |
Apple bootcamp ver. 1809 32-bit... File Disconnect/Connect updates historical Intraday but Socket closes by Remote Side, so no continuous feed. Got 4 Green's at "Exchange data / instructions". Read all help pages, unblocked Firewall, lengthened feed to 1500 mills, just one symbol Cash $SPX, 7 unattached charts, 1 minute - weekly. Worked flawlessly with 50 symbols / unattached charts when I was following SPY through TD Am.
[2018-09-27 22:33:40] |
Refer to this section for instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData Basically in your case you just need to activate the S&P Indices exchange and use the symbol $INX instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-28 14:42:39] |
Thanks... I'll save reply and use later. Kudos for the Technical Service and a program that is Pure Genius.
