Date/Time: Thu, 02 May 2024 05:51:57 +0000
Unexpexted printing with TPO
View Count: 455
[2018-09-27 15:42:05] |
User877753 - Posts: 152 |
Hello, Weird printing on my computer and printer for TPO charts. Attached, from the same chart : screenshot and PDF (from Nuance), obtained from File/Print. Can you reproduce this issue ? Any clue ? Thanks in advance. Regards, JM |
DAX-201812-DTB-EUR-5 [CB] [M] #8 2018-09-27 17_38_54.880.png / V - Attached On 2018-09-27 15:40:15 UTC - Size: 73.7 KB - 179 views DAX-201812-DTB-EUR-5 [CB] [M] #8.pdf - Attached On 2018-09-27 15:40:23 UTC - Size: 58.87 KB - 220 views |
[2018-09-28 02:08:36] |
This will be solved in the next release coming out later today.
