Date/Time: Mon, 06 May 2024 11:23:00 +0000
Holding Overnight Positions in SC
View Count: 744
[2018-09-27 03:45:14] |
User379468 - Posts: 508 |
I've primary done intraday trading with SC only. Are there any issues or limitations using SC for swing trading and holding overnight positions/orders, with CTS or other services? Assuming Global PnL Management must be disabled, anything else to consider? |
[2018-09-27 15:09:56] |
You can do this without any problem.
[2018-10-29 22:19:10] |
Would Trade Stats for Charts work correctly as the place to track PnL of open overnight/swing positions?
[2018-10-30 15:54:16] |
You really just need to look at the Trade Positions tab. Refer to the documentation here: Trading Information Windows: Trade Positions Window The Trade Stats for Charts tab is not going to be entirely reliable: Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-30 15:55:24
