Date/Time: Sat, 04 May 2024 13:29:35 +0000
Transfering my charts
View Count: 804
[2018-09-27 03:03:24] |
gmorgan111 - Posts: 121 |
I have purchased a new computer desktop. I have downloaded the Sierra Chart platform which I have been using for several years. I do not want to set up all new charts and workspaces. Is there a way to transfer my chartbooks from my old computer to my new computer. I went into the Sierra Chart folder and found the data folder but it is a large file of 183 GB I don't know why it is so big but I would like to just move my chartbooks to my new computer so I do not have to build them from scratch. Is there a way to do this? Thanks |
[2018-09-27 15:09:32] |
Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Copy all the files as documented except for the files with a file extension scid. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
