Date/Time: Thu, 16 May 2024 13:46:07 +0000
Sierra Chart Replay Mode has Suddenly stopped working.
View Count: 903
[2018-09-26 21:37:36] |
User747196 - Posts: 7 |
I have used Sierra Chart for years. Yesterday, I activated the "Replay" mode. I found that you have changed the replay window to the point where it is no longer usable. Since the reason that I have used Sierra Chart for all these years is for "practice trading", and trying out new ideas, then it doesn't make sense to continue my subscription if the "Replay" function no longer works. Please look into this for me. Thanks, |
[2018-09-27 14:08:02] |
This post makes no sense whatsoever. Tell us what the issue is. The Chart Replay window is the same and has some additional functionality on it. Tell us what the problem is. Here is the replay documentation: Replaying Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-28 10:19:50] |
Alberto Gauer - Posts: 121 |
I am sorry, but I have to lol
[2018-09-28 17:35:51] |
Your posts here are completely illegitimate. Do not post anything further on the subject unless you can explain the issue in your case.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-28 17:36:07
