Date/Time: Tue, 07 May 2024 10:38:57 +0000
Windows error code 10053
View Count: 957
[2018-09-26 18:13:03] |
Joseph Keller - Posts: 19 |
I am getting a "Windows error code 10053: An established connection was aborted by the software in your host machine." This just started today. I have not changed accounts or anything. I have the current version of SC. This same errors occurs on different computers when I log into SC.
[2018-09-26 19:19:34] |
John - SC Support - Posts: 31419 |
If you are using TD Ameritrade for your data then perform the following steps: Go to "File >> Data/Trade Service Settings". Set Streamer Address Override to: streamer-ext-bin-tx.tdameritrade.com Reconnect to the data feed by selecting, "File >> Disconnect" and then "File >> Connect To Data Feed". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
