Date/Time: Fri, 03 May 2024 05:20:18 +0000
Changing connection of Sierra to other broker
View Count: 612
[2018-09-26 16:47:59] |
User820337 - Posts: 4 |
Hello Sir, I have a question; having bought the subscription for sierra chart...is it possible for me to change connection to other Broker within the same month of the paid subscription? Let's say I've been using Sierra with AMP and today I'd like to switch connection to Advantage futures. Is it doable? If yes, how to do it? I'll be grateful for help, Best regards, Tomasz |
[2018-09-28 02:28:47] |
Yes you can do this at any time without any restrictions. It does not require any involvement from us. Simply refer to the supported Data and Trading services page for instructions: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-28 02:29:05
