Date/Time: Thu, 16 May 2024 00:10:06 +0000
Custom color buttons not working on Control Bar 1
View Count: 701
[2018-09-26 13:10:13] |
Meklon - Posts: 218 |
Hello support, I just upgraded to the latest version 1807 and my custom colors for the buttons on Control Bar 1 no longer working. When I check the settings, I see that the color is set properly but on the Control bar all buttons are still gray. Please advise. Thank you. |
[2018-09-26 14:35:01] |
SC Developer - David - Posts: 660 |
If you are referring to Custom Text Drawing Buttons, then you also need to check "Use Custom Text Tool Color for Button Text" check box on Customize Control Bar 1 dialog to apply Custom Text Drawing Buttons' color to Control bar buttons.
Date Time Of Last Edit: 2018-09-26 14:35:56
[2018-09-26 14:43:33] |
I am referring to the standard (not Custom Text Drawing) buttons available on the list of Control Bar 1. Specifically, the Extending Rectangle which I have always colored Cyan is now Grey but in the configuration the color settings are set properly. Please see attached image.
Date Time Of Last Edit: 2018-09-26 17:16:45
Button_Color_Missing.png / V - Attached On 2018-09-26 14:43:20 UTC - Size: 71.79 KB - 228 views |
[2018-09-26 16:44:30] |
John - SC Support - Posts: 31666 |
We are aware of this issue and we are looking into it.
[2018-09-28 14:36:08] |
Hello support, any update on this?
[2018-09-28 15:13:51] |
Yes, this particular issue has been resolved in the latest release, although there appears to be a new issue where it is hard to tell that the button has been depressed. This latest issue is still being worked on.
