Date/Time: Fri, 03 May 2024 13:48:07 +0000
Message Log Will not Close
View Count: 894
[2018-09-26 12:49:34] |
NiceGuy23 - Posts: 2 |
Incredibly annoying, not sure what the deal is, there is some issue that sierra keeps populating in the message log. How do I fix this........ TD Ameritrade | Streamer request #362 initiated. | 2018-09-26 08:47:30 HTTPS connection to ameritrade02.streamer.com:443 (1578) | Creating socket. Using TLS 1.0. | 2018-09-26 08:47:30 HTTPS connection to ameritrade02.streamer.com:443 (1578) | Connecting to IP: 198.200.171.137. | 2018-09-26 08:47:30 HTTPS connection to ameritrade02.streamer.com:443 (1578) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 08:47:31 HTTPS connection to ameritrade02.streamer.com:443 (1578) | Signaling to core to close socket | 2018-09-26 08:47:31 TD Ameritrade | Lost the connection with the streamer. Request ID: 362. Will re-request data. | 2018-09-26 08:47:31 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 08:47:31 HTTPS connection to ameritrade02.streamer.com:443 (1578) | Shutdown started. Waiting for graceful close. | 2018-09-26 08:47:31 HTTPS connection to ameritrade02.streamer.com:443 (1578) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 08:47:31 * HTTPS connection to ameritrade02.streamer.com:443 (1578) | Received socket Close event. | 2018-09-26 08:47:31 HTTPS connection to ameritrade02.streamer.com:443 (1578) | Still waiting for graceful close or receive error. | 2018-09-26 08:47:31 TD Ameritrade | Streamer request #363 initiated. | 2018-09-26 08:47:33 HTTPS connection to ameritrade02.streamer.com:443 (1579) | Creating socket. Using TLS 1.0. | 2018-09-26 08:47:33 HTTPS connection to ameritrade02.streamer.com:443 (1579) | Connecting to IP: 198.200.171.137. | 2018-09-26 08:47:33 HTTPS connection to ameritrade02.streamer.com:443 (1579) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 08:47:33 HTTPS connection to ameritrade02.streamer.com:443 (1579) | Signaling to core to close socket | 2018-09-26 08:47:33 TD Ameritrade | Lost the connection with the streamer. Request ID: 363. Will re-request data. | 2018-09-26 08:47:33 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 08:47:33 HTTPS connection to ameritrade02.streamer.com:443 (1579) | Shutdown started. Waiting for graceful close. | 2018-09-26 08:47:33 HTTPS connection to ameritrade02.streamer.com:443 (1579) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 08:47:33 * HTTPS connection to ameritrade02.streamer.com:443 (1579) | Received socket Close event. | 2018-09-26 08:47:33 HTTPS connection to ameritrade02.streamer.com:443 (1579) | Still waiting for graceful close or receive error. | 2018-09-26 08:47:33 |
[2018-09-26 19:17:48] |
John - SC Support - Posts: 31334 |
In order to fix the problem with the TD Ameritrade Data, perform the following steps: Go to "File >> Data/Trade Service Settings". Set Streamer Address Override to: streamer-ext-bin-tx.tdameritrade.com Reconnect to the data feed by selecting, "File >> Disconnect" and then "File >> Connect To Data Feed". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
