Date/Time: Tue, 07 May 2024 10:53:27 +0000
Stand Alone DOM - Totals & Percentages
View Count: 1484
[2018-09-26 10:38:59] |
User360283 - Posts: 440 |
Can the stand alone DOM display the Totals and Percentages the same as on the Market Depth window? Would be very useful. Thanks
[2018-09-26 12:11:56] |
Also. Can you add a field called "BIAS" that would be the difference between the Bid Quantity Percentage and the Ask Quantity Percentage. And color the background based on whether the bias is tow sell (Red) or Buy (Green). Would be very helpful. And on the Market Depth Window for the ES there are NO values for the Bid Orders and Ask Orders. Is this correct? |
[2018-09-26 13:41:29] |
Can the Market Depth Window Totals and Percentages and the "BIAS" be made available for plotting in studies? Thanks
[2018-09-26 16:26:06] |
Can Market Depth additionally display the Average of the Buy and Sell quantities and somehow highlight (via color or font (bold?) the rows of both the Buy and Sell with the largest QTY. And also make all of this info available on the stand alone DOM. Thanks |
[2018-09-28 02:30:35] |
You could use the DOM Graph and then visually identify the largest level: Trade Menu: Draw DOM Graph on Chart (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-28 09:00:50] |
Thanks. I tried the DOM graph. Clutters up my charts too much. I would like to see the Market Depth Totals and Percentages displayed on the Stand Alone DOM. Possible under the Column Headings (P&L Buy Sell)? Thanks |
[2018-09-28 12:57:54] |
To clarify: Adding the Market Depth Totals and Percentages in tow additional rows under the Stand Alone DOM column headings would be very useful by minimizing the places one has to focus on. Thanks |
[2018-10-07 22:00:15] |
Would really like the stand alone DOM display the Totals and Percentages the same as on the Market Depth window? Would be very useful. And to have the Average Bid and Ask AVERAGE price rows highlighted. Thsnks
