Date/Time: Fri, 03 May 2024 08:34:41 +0000
Continuous futures contracts issue on ES, NQ DAX (not CL)
View Count: 1311
[2018-09-26 06:33:50] |
User877753 - Posts: 152 |
Hello, Configuration : SC feed + IB. Unexpected appearance for ES NQ and DAX contract : same data appear with - continuous contract = none - continuous contract = date rule rollover, back adjusted. Appears like the current future contract is not chained with previous one. Same problem with intraday and daiily data. Adding volume study confirms the point. Curiously, CL contract works fine. Thanks for your help. JM PS : Got it : In "Symbol settings", the list of rules in dropbox for "Rollover rules" changed. CL rule itme went unchanged. However, the items I selected for ES NQ and DAX were modified, so the dropbox selection went to "Not defined". Proper selection fixes it. Best regards, Date Time Of Last Edit: 2018-09-26 07:01:20
[2018-09-27 14:48:59] |
This is now resolved in the latest revision of pre-release 1812.
