Date/Time: Sat, 04 May 2024 13:02:24 +0000
Sierra Chart Market Data Subscription
View Count: 1506
[2018-10-01 13:14:38] |
User94606 - Posts: 327 |
I read post #22 and tested it and it is working fine. However, when I do a "New Instance" of Sierra Chart and select either ES or CL, the "M" does not display on any charts. I then logged in to my live account and still does not show "M". Is this correct? Also, I noticed that the market depth on CL is only 10 levels whereas the ES greater than 10 levels. Can you confirm if this is correct? |
[2018-10-01 18:40:14] |
When using a sub instance of Sierra Chart through File >> New Instance, you will not see the [M] but this data feed is still being used for the symbol if you do see the [M] indicator for the symbol in the main instance of Sierra Chart.
More levels of depth for CL will be coming at the end of this week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
