Date/Time: Sun, 28 Apr 2024 15:08:46 +0000
[User Discussion] - Numbers bars calculated value and spreadsheets
View Count: 1152
[2018-09-25 21:28:47] |
User809700 - Posts: 14 |
Hi, Currently have a chart with Numbers Bars Calculated Value(ID 1) attached with 4 subgraphs visible. When i then attach a Spreadsheet for trading study, i do not see id:1 (NBCV) in the expected AA column. Not sure why as i have previously used the NBCV study within spreadsheets. Perhaps there is a new setting? Any insight would be appreciated. Thanks |
[2018-09-25 21:39:36] |
Sawtooth - Posts: 3980 |
Works for me. The NBCV study's SG1 is Ask Volume Bid Volume Difference This output appears in column AA only if the 'Number of Formula Columns' is set to 16, and if the NBCV study is at the top of the Studies to Graph list. |
[2018-09-25 21:50:30] |
Hi Tom, Yea, its kind of weird . . . i am currently on sierra version 1809. Only two studies: id1 is NBCV (3 subgraphs visible), id2 Spreadsheet for trading. I have even added other studies above the spreadsheet for trading and they do appear in AA, so the "issue" must be with NBCV . . . <headscrating> |
[2018-09-25 21:56:36] |
The NBCV study works for me in v1803. Try reverting to that earlier version.
[2018-09-26 12:23:31] |
Tom, thanks for the suggestion, however still no luck with 1803. Perhaps the sierra guys would like me to upload a chartbook or log to see if the error resides on my end. |
[2018-09-26 16:08:40] |
Refer to the following: Using the Spreadsheet Study: Solving Study Not Displaying On Spreadsheet Sheet Be sure you have the Subgraphs that you want to show up in the Spreadsheet set to Include in Spreadsheet. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-28 23:17:27] |
This worked...Thanks Sierra and Tom
