Date/Time: Tue, 14 May 2024 16:12:52 +0000
Pivots - 4 Hour Timeframe
View Count: 608
[2018-09-25 15:24:33] |
User337568 - Posts: 60 |
Hello: Looking to create a variable pivot for 4 Hours, using a length of 6. I looked through the manual and support board and I see minutes and not hours. Any help is appreciated. Harndog |
[2018-09-25 16:00:01] |
Thank you. I tried that and I am looking to set the length at 6. I.e. Show me the pivot on a 4 Hour timeframe using a length of 6. An improvement would be adding "hour" as a time variable. Harndog |
[2018-09-25 18:29:07] |
Use a setting of 360 Minutes
