Date/Time: Sun, 05 May 2024 16:35:57 +0000
Order Error
View Count: 575
[2018-09-25 14:50:50] |
Joseph Keller - Posts: 19 |
I received the following Order Error and not sure what to do to fix this? Trade Activity Log: File read result: 317 records inserted. 32 fill records inserted. 0 records filtered. | 2018-09-23 21:55:38 Trade Activity Log: File date-time limits: Sim records date-time limit is 2018-09-08 00:00:00. Non-sim records date-time limit is 2018-06-22 00:00:00. Non-sim fill record date-time limit is 2017-09-23 00:00:00. | 2018-09-23 21:55:38 Order Error - TDA order update. Please enter a valid stock symbol. Internal Order ID: 2302. Service Order ID: (none). Symbol: EURCAD | 2018-09-24 06:30:01 * Order Error - TDA order update. Please enter a valid stock symbol. Internal Order ID: 2305. Service Order ID: (none). Symbol: EURCAD | 2018-09-24 07:00:00 * |
[2018-09-25 17:05:30] |
You can only trade stock symbols with TD Ameritrade. Not Forex.
[2018-09-25 22:12:55] |
Is that a limitation on Sierra Charts as my ThinkorSwim platform (TD Ameritrade) allows FX trades?
[2018-09-27 22:42:09] |
We apologize for the delay. This is a limitation of the TD Ameritrade API they provide. More information is here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#TradingWithTDAmeritradeonSC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-27 22:42:27
