Date/Time: Mon, 06 May 2024 14:22:45 +0000
Kind request - expansion of VWAP rolling study for long term trading and investing
View Count: 916
[2018-09-24 19:15:55] |
User995923 - Posts: 64 |
Hello I would be very grateful if you could expand the time period type of the VWAP - Rolling study to include Weeks - trading weeks (aka the continuation of previous week's VWAP), trading months, quarters and years. Please consider it, especially if it does not require any significant programming resources as it will improve the capabilities of SC for long term trading and investing. Regards |
[2018-09-25 04:58:12] |
Should not be a problem. We will see about this.
[2018-09-30 17:31:52] |
Hello Is there any update on this? |
[2018-09-30 21:01:49] |
No not yet. Hopefully we could get to it this week.
[2019-04-14 07:49:22] |
Hello I see this request was discontinued. Can you please add the setting options stated above in the VWAP rolling study? It would help me very much as I focus on higher timeframes. Regards |
[2019-04-17 02:30:26] |
We will try to work on this over the weekend.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 02:31:05
[2019-04-17 18:39:19] |
We did have a look at this, and this is not simple to add support for. We will get to this at some point but we do not know when.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 18:39:33
[2024-03-12 06:14:31] |
User834748 - Posts: 3 |
Hello, Was this ever added to the roadmap? It would be an extremely helpful feature. Thanks. |
