Date/Time: Sun, 12 May 2024 07:32:47 +0000
DlyPL incorrect in Trade Window
View Count: 552
[2018-09-24 13:58:58] |
User568539 - Posts: 18 |
Hi. I was using the Simulation Mode in Prerelease Version 1811, and in the Trade Window "DlyPL" it is incorrectly showing 0, instead of showing the correct amount of the Currency Value(C) or Ticks(T) or Points(P), etc. Thank you.
[2018-09-24 19:32:39] |
You need to go back to the current version from the prerelease. This functionality is still under development in 1811.
