Date/Time: Sun, 05 May 2024 15:22:54 +0000
Can't Color Arrow and Lines etc with 1809 version
View Count: 558
[2018-09-24 13:16:07] |
User56044 - Posts: 62 |
I installed the latest 1809 version of Sierra. Now, when I draw lines or arrows etc I can't color them when I right click on the item. When I right or left click on an arrow/line etc no dots appear on the item and no color option appears. This happens on all of my charts. Help!!
[2018-09-24 19:38:57] |
We do not see a problem with this. But we will look more into this. Do you use an usually small text size on the chart?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-24 19:39:07
[2018-09-24 19:59:48] |
Text is normal size and I can add text to the chart and when I click on that text it is highlighted and I can then delete it. However, I cannot highlight arrows or lines and therefore cannot change their color or delete them other than to go into the tools menu and delete them from there.
[2018-09-24 21:54:43] |
We will get this resolved. Just give us one or two days.
[2018-10-03 21:11:14] |
John - SC Support - Posts: 31366 |
There has been work done to change how drawings are selected. This has been completed and is in the current release.
