Date/Time: Fri, 10 May 2024 03:20:12 +0000
Not getting data on second real-time data connection
View Count: 609
[2018-09-24 07:33:22] |
User87744 - Posts: 22 |
Hi, I subscribed to two real-time data connections but am only able to get one connection. I am getting teh following message: SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:22 Full message log as follows. Thanks in advance for your help. Reading Internal Order ID file. | 2018-09-24 03:21:30 Reading Trade Orders file. | 2018-09-24 03:21:31 Reading Trade Positions and Account Balance file. | 2018-09-24 03:21:31 Error binding to UDP port 22903. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2018-09-24 03:21:31 Software version: 1795 32-bit | 2018-09-24 03:21:31 Usage end date: 2018-10-11 | 2018-09-24 03:21:31 Enabled for: Advanced Features. | 2018-09-24 03:21:31 Enabled for: Sierra Chart Historical Data Service. | 2018-09-24 03:21:31 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-09-24 03:21:31 Enabled for: INDEXES_DATA_BARCHART | 2018-09-24 03:21:31 Enabled for: CME (Trading Account Required) | 2018-09-24 03:21:31 Enabled for: CBOT (Trading Account Required) | 2018-09-24 03:21:31 Enabled for: COMEX (Trading Account Required) | 2018-09-24 03:21:31 Enabled for: NYMEX (Trading Account Required) | 2018-09-24 03:21:31 Enabled for: Eurex with Market Depth | 2018-09-24 03:21:31 Enabled for: Hong Kong Futures Exchange | 2018-09-24 03:21:31 Received 2 data feed usernames. | 2018-09-24 03:21:31 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-09-24 03:21:31 Current selected Data/Trading service: SC Data - All Services | 2018-09-24 03:21:31 Chart Update Interval: 500 | 2018-09-24 03:21:31 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-09-24 03:21:31 2018-09-24 15:21:31 Local computer time | 2018-09-24 03:21:31 2018-09-24 07:21:31 Local computer time in UTC | 2018-09-24 03:21:31 2018-09-24 03:21:31 Local computer time in SC Time Zone | 2018-09-24 03:21:31 2018-09-24 07:21:29 Server time in UTC | 2018-09-24 03:21:31 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-09-24 03:21:31 Program path: E:\SierraChart\ | 2018-09-24 03:21:31 Data Files path: E:\SierraChart\Data\ | 2018-09-24 03:21:31 OS Version Number: 10.0 | 2018-09-24 03:21:31 Locale Setting: C | 2018-09-24 03:21:31 Created the DTC Protocol server. | 2018-09-24 03:21:31 Listening socket (1480). Port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2018-09-24 03:21:31 * Listening socket (1480). Port 0 | Closed. | 2018-09-24 03:21:31 DTC Protocol Server failed to start listening on port 11099. | 2018-09-24 03:21:31 * Created the DTC Protocol historical data server. | 2018-09-24 03:21:31 Listening socket (1484). Port 0 | Failed to bind socket to 0.0.0.0:11098. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2018-09-24 03:21:31 * Listening socket (1484). Port 0 | Closed. | 2018-09-24 03:21:31 HD Server Manager | Error starting listening socket on port 11098 | 2018-09-24 03:21:31 Checking for new symbol settings for service code scdataallservices | 2018-09-24 03:21:31 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-09-24 03:21:31 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-09-24 03:21:31 Received 5 login tokens. | 2018-09-24 03:21:32 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-09-24 03:21:33 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-09-24 03:21:33 HTTPS connection to login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-09-24 03:21:35 HTTPS connection to login.sierrachart.com:443 (1) | Received socket Close event. | 2018-09-24 03:21:35 HTTPS connection to login.sierrachart.com:443 (1) | Initiating close of socket by core. | 2018-09-24 03:21:35 HTTPS connection to login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:21:35 HTTPS connection to login.sierrachart.com:443 (1) | Closed. | 2018-09-24 03:21:35 Symbol settings are up-to-date for scdataallservices | 2018-09-24 03:21:35 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-09-24 03:21:37 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-09-24 03:21:37 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-09-24 03:21:37 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:21:37 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-09-24 03:21:37 SC Data - All Services | Connected to data server. | 2018-09-24 03:21:37 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-09-24 03:21:39 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-09-24 03:21:39 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-09-24 03:21:39 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:21:39 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-09-24 03:21:39 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-09-24 03:21:40 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-09-24 03:21:40 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-09-24 03:21:40 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:21:40 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-09-24 03:21:40 DYZ18 [CBV] Flex Renko 10-2-2 #4 | Reloading chart. | 2018-09-24 03:22:13 DYZ18 [CBV] 7950 Trades #17 | Reloading chart. | 2018-09-24 03:22:14 DYZ18 [CBV] 1 Min #1 | Reloading chart. | 2018-09-24 03:22:14 Mapping DYZ18 to DYZ18. Service code: eurex | 2018-09-24 03:22:15 SC Data - All Services | Starting real-time market data updates for: DYZ18. ID: 1 | 2018-09-24 03:22:15 SC Data - All Services | Using username 0 | 2018-09-24 03:22:15 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-24 03:22:15 DTC Client socket (6) | Creating socket. | 2018-09-24 03:22:15 DTC Client socket (6) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:22:15 SC Data - All Services | Requesting security definition data for: DYZ18. ID: 1 | 2018-09-24 03:22:15 Intraday data recording state for symbol DYZ18 is set to download 'Pending'. | 2018-09-24 03:22:15 Delaying start of download for DYZ18 | 2018-09-24 03:22:15 SC Data - All Services | Connected to server. | 2018-09-24 03:22:15 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:15 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:15 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:15 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:15 SC Data - All Services | Received logon response. | 2018-09-24 03:22:15 DTC Client socket (6) | Socket gracefully closed by remote side. | 2018-09-24 03:22:15 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:15 DTC Client socket (6) | Received socket Close event. | 2018-09-24 03:22:15 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:15 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:15 DTC Client socket (6) | Initiating close of socket by core. | 2018-09-24 03:22:15 DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:15 DTC Client socket (6) | Closed. | 2018-09-24 03:22:15 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:15 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:15 SC Data - All Services | Using username 1 | 2018-09-24 03:22:17 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2018-09-24 03:22:17 DTC Client socket (7) | Creating socket. | 2018-09-24 03:22:17 DTC Client socket (7) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:22:17 SC Data - All Services | Connected to server. | 2018-09-24 03:22:18 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:18 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:18 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:18 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:18 DTC Client socket (7) | Received socket Close event. | 2018-09-24 03:22:18 DTC Client socket (7) | Socket gracefully closed by remote side. | 2018-09-24 03:22:18 DTC Client socket (7) | Signaling for receive thread to end. Bytes in receive buffer: 142 | 2018-09-24 03:22:18 DTC Client socket (7) | Initiating close of socket by core. | 2018-09-24 03:22:18 DTC Client socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:18 DTC Client socket (7) | Closed. | 2018-09-24 03:22:18 SC Data - All Services | Received logon response. | 2018-09-24 03:22:18 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:18 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:18 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:18 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:18 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:18 SC Data - All Services | Using username 0 | 2018-09-24 03:22:20 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-24 03:22:20 DTC Client socket (8) | Creating socket. | 2018-09-24 03:22:20 DTC Client socket (8) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:22:20 Chart #17 has tagged chart #4 for full recalculation. Chartbook: algo1_FDAX.Cht | 2018-09-24 03:22:20 Chart #17 has tagged chart #4 for full recalculation. Chartbook: algo1_FDAX.Cht | 2018-09-24 03:22:20 SC Data - All Services | Connected to server. | 2018-09-24 03:22:20 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:20 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:20 DYZ18 [CBV] [M] Flex Renko 10-2-2 #4 | Performing a full recalculation because it has been tagged. Chartbook: algo1_FDAX.Cht | 2018-09-24 03:22:20 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:24 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:24 DTC Client socket (8) | Received socket Close event. | 2018-09-24 03:22:24 DTC Client socket (8) | Socket gracefully closed by remote side. | 2018-09-24 03:22:24 DTC Client socket (8) | Signaling for receive thread to end. Bytes in receive buffer: 142 | 2018-09-24 03:22:24 DTC Client socket (8) | Initiating close of socket by core. | 2018-09-24 03:22:24 DTC Client socket (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:24 DTC Client socket (8) | Closed. | 2018-09-24 03:22:24 SC Data - All Services | Received logon response. | 2018-09-24 03:22:24 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:24 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:24 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:24 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:24 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:24 SC Data - All Services | Using username 1 | 2018-09-24 03:22:26 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2018-09-24 03:22:26 DTC Client socket (9) | Creating socket. | 2018-09-24 03:22:26 DTC Client socket (9) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:22:26 SC Data - All Services | Connected to server. | 2018-09-24 03:22:27 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:27 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:27 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:27 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:27 DTC Client socket (9) | Received socket Close event. | 2018-09-24 03:22:27 DTC Client socket (9) | Socket gracefully closed by remote side. | 2018-09-24 03:22:27 DTC Client socket (9) | Signaling for receive thread to end. Bytes in receive buffer: 142 | 2018-09-24 03:22:27 DTC Client socket (9) | Initiating close of socket by core. | 2018-09-24 03:22:27 DTC Client socket (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:27 DTC Client socket (9) | Closed. | 2018-09-24 03:22:27 SC Data - All Services | Received logon response. | 2018-09-24 03:22:27 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:27 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:27 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:27 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:27 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:27 SC Data - All Services | Using username 0 | 2018-09-24 03:22:29 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2018-09-24 03:22:29 DTC Client socket (10) | Creating socket. | 2018-09-24 03:22:29 DTC Client socket (10) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:22:29 SC Data - All Services | Connected to server. | 2018-09-24 03:22:29 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:29 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:29 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:30 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:30 SC Data - All Services | Received logon response. | 2018-09-24 03:22:30 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:30 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:30 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:30 DTC Client socket (10) | Socket gracefully closed by remote side. | 2018-09-24 03:22:30 DTC Client socket (10) | Received socket Close event. | 2018-09-24 03:22:30 DTC Client socket (10) | Initiating close of socket by core. | 2018-09-24 03:22:30 DTC Client socket (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:30 DTC Client socket (10) | Closed. | 2018-09-24 03:22:30 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:30 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:30 Listening socket (1588). Port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2018-09-24 03:22:31 * Listening socket (1588). Port 0 | Closed. | 2018-09-24 03:22:31 DTC Protocol Server failed to start listening on port 11099. | 2018-09-24 03:22:31 * SC Data - All Services | Using username 1 | 2018-09-24 03:22:32 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2018-09-24 03:22:32 DTC Client socket (12) | Creating socket. | 2018-09-24 03:22:32 DTC Client socket (12) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:22:32 SC Data - All Services | Connected to server. | 2018-09-24 03:22:32 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:32 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:32 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:32 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:32 DTC Client socket (12) | Received socket Close event. | 2018-09-24 03:22:33 DTC Client socket (12) | Socket gracefully closed by remote side. | 2018-09-24 03:22:33 DTC Client socket (12) | Initiating close of socket by core. | 2018-09-24 03:22:33 DTC Client socket (12) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:33 DTC Client socket (12) | Closed. | 2018-09-24 03:22:33 SC Data - All Services | Received logon response. | 2018-09-24 03:22:33 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:33 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:33 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:33 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:33 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:33 NQZ18 [CBV] Flex Renko 10-2-2 #4 | Reloading chart. | 2018-09-24 03:22:34 NQZ18 [CBV] 15900 Trades #17 | Reloading chart. | 2018-09-24 03:22:34 NQZ18 [CBV] 5600 Trades #20 | Reloading chart. | 2018-09-24 03:22:34 NQZ18 [CBV] Daily #1 | Reloading chart. | 2018-09-24 03:22:35 Mapping NQZ18 to NQZ18. Service code: cme | 2018-09-24 03:22:36 SC Data - All Services | Starting real-time market data updates for: NQZ18. ID: 2 | 2018-09-24 03:22:36 SC Data - All Services | Requesting security definition data for: NQZ18. ID: 2 | 2018-09-24 03:22:36 Intraday data recording state for symbol NQZ18 is set to download 'Pending'. | 2018-09-24 03:22:36 SC Data - All Services | Using username 0 | 2018-09-24 03:22:36 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2018-09-24 03:22:36 DTC Client socket (13) | Creating socket. | 2018-09-24 03:22:36 DTC Client socket (13) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:22:36 HD Request # 2 | Downloading Historical Daily chart data for NQZ18. Starting date: 2018-09-21. Service: scdataallservices | 2018-09-24 03:22:36 HD Request # 2 | Using user Barchart Historical data account. | 2018-09-24 03:22:36 HD Request # 2 | Requesting historical Daily data for NQZ18 starting at 2018-09-20 | 2018-09-24 03:22:36 HTTPS connection to historicaldata.sierrachart.com:443 (14) | Creating socket. Using TLS 1.2. | 2018-09-24 03:22:36 HTTPS connection to historicaldata.sierrachart.com:443 (14) | Connecting to IP: 88.99.0.216. | 2018-09-24 03:22:36 SC Data - All Services | Connected to server. | 2018-09-24 03:22:36 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:36 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:36 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:37 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:37 SC Data - All Services | Received logon response. | 2018-09-24 03:22:37 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:37 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:37 DTC Client socket (13) | Socket gracefully closed by remote side. | 2018-09-24 03:22:37 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:37 DTC Client socket (13) | Received socket Close event. | 2018-09-24 03:22:37 DTC Client socket (13) | Initiating close of socket by core. | 2018-09-24 03:22:37 DTC Client socket (13) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:37 DTC Client socket (13) | Closed. | 2018-09-24 03:22:37 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:37 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:37 HD Request # 2 | Receiving historical Daily data for NQZ18 starting at 2018-09-21 | 2018-09-24 03:22:38 HD Request # 2 | Writing historical Daily data to the file NQZ18.dly | 2018-09-24 03:22:38 HD Request # 2 | Received 3 records from 2018-09-21 00:00:00 to 2018-09-24 00:00:00 (4.0 days) and wrote 2 records for NQZ18 | 2018-09-24 03:22:38 HD Request # 2 | Completion time: 2s | 2018-09-24 03:22:38 HD Request # 2 | Daily data download complete for NQZ18. Unique request ID: 3 | 2018-09-24 03:22:38 Removed historical data download ID 3 | 2018-09-24 03:22:38 NQZ18 [CBV] [M] Daily #1 | Reloading chart. | 2018-09-24 03:22:38 SC Data - All Services | Using username 1 | 2018-09-24 03:22:40 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2018-09-24 03:22:40 DTC Client socket (15) | Creating socket. | 2018-09-24 03:22:40 DTC Client socket (15) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:22:40 SC Data - All Services | Connected to server. | 2018-09-24 03:22:40 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:40 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:40 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:40 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:40 DTC Client socket (15) | Received socket Close event. | 2018-09-24 03:22:40 DTC Client socket (15) | Socket gracefully closed by remote side. | 2018-09-24 03:22:40 DTC Client socket (15) | Initiating close of socket by core. | 2018-09-24 03:22:40 DTC Client socket (15) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:40 DTC Client socket (15) | Closed. | 2018-09-24 03:22:40 SC Data - All Services | Received logon response. | 2018-09-24 03:22:40 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:40 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:40 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:40 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:40 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:40 SC Data - All Services | Using username 0 | 2018-09-24 03:22:42 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-24 03:22:42 DTC Client socket (16) | Creating socket. | 2018-09-24 03:22:42 DTC Client socket (16) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:22:42 SC Data - All Services | Connected to server. | 2018-09-24 03:22:43 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:43 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:43 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:43 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:43 DTC Client socket (16) | Socket gracefully closed by remote side. | 2018-09-24 03:22:43 DTC Client socket (16) | Received socket Close event. | 2018-09-24 03:22:43 DTC Client socket (16) | Initiating close of socket by core. | 2018-09-24 03:22:43 DTC Client socket (16) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:43 DTC Client socket (16) | Closed. | 2018-09-24 03:22:43 SC Data - All Services | Received logon response. | 2018-09-24 03:22:43 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:43 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:43 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:43 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:43 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:43 SC Data - All Services | Using username 1 | 2018-09-24 03:22:45 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2018-09-24 03:22:45 DTC Client socket (17) | Creating socket. | 2018-09-24 03:22:45 DTC Client socket (17) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:22:45 SC Data - All Services | Connected to server. | 2018-09-24 03:22:45 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:45 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:45 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:45 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:45 SC Data - All Services | Received logon response. | 2018-09-24 03:22:46 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:46 DTC Client socket (17) | Socket gracefully closed by remote side. | 2018-09-24 03:22:46 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:46 DTC Client socket (17) | Received socket Close event. | 2018-09-24 03:22:46 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:46 DTC Client socket (17) | Initiating close of socket by core. | 2018-09-24 03:22:46 DTC Client socket (17) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:46 DTC Client socket (17) | Closed. | 2018-09-24 03:22:46 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:46 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:46 SC Data - All Services | Using username 0 | 2018-09-24 03:22:48 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-24 03:22:48 DTC Client socket (18) | Creating socket. | 2018-09-24 03:22:48 DTC Client socket (18) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:22:48 SC Data - All Services | Connected to server. | 2018-09-24 03:22:48 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:48 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:48 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:48 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:48 DTC Client socket (18) | Received socket Close event. | 2018-09-24 03:22:48 DTC Client socket (18) | Socket gracefully closed by remote side. | 2018-09-24 03:22:48 DTC Client socket (18) | Initiating close of socket by core. | 2018-09-24 03:22:48 DTC Client socket (18) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:48 DTC Client socket (18) | Closed. | 2018-09-24 03:22:48 SC Data - All Services | Received logon response. | 2018-09-24 03:22:48 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:48 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:48 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:48 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:48 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:48 SC Data - All Services | Using username 1 | 2018-09-24 03:22:50 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2018-09-24 03:22:50 DTC Client socket (19) | Creating socket. | 2018-09-24 03:22:50 DTC Client socket (19) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:22:50 SC Data - All Services | Connected to server. | 2018-09-24 03:22:51 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:51 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:51 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:51 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:51 DTC Client socket (19) | Socket gracefully closed by remote side. | 2018-09-24 03:22:51 SC Data - All Services | Received logon response. | 2018-09-24 03:22:51 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:51 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:51 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:51 DTC Client socket (19) | Received socket Close event. | 2018-09-24 03:22:51 DTC Client socket (19) | Initiating close of socket by core. | 2018-09-24 03:22:51 DTC Client socket (19) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:51 DTC Client socket (19) | Closed. | 2018-09-24 03:22:51 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:51 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:51 SC Data - All Services | Using username 0 | 2018-09-24 03:22:53 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-24 03:22:53 DTC Client socket (20) | Creating socket. | 2018-09-24 03:22:53 DTC Client socket (20) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:22:53 SC Data - All Services | Connected to server. | 2018-09-24 03:22:53 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:53 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:53 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:53 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:53 SC Data - All Services | Received logon response. | 2018-09-24 03:22:54 DTC Client socket (20) | Socket gracefully closed by remote side. | 2018-09-24 03:22:54 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:54 DTC Client socket (20) | Received socket Close event. | 2018-09-24 03:22:54 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:54 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:54 DTC Client socket (20) | Initiating close of socket by core. | 2018-09-24 03:22:54 DTC Client socket (20) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:54 DTC Client socket (20) | Closed. | 2018-09-24 03:22:54 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:54 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:54 SC Data - All Services | Using username 1 | 2018-09-24 03:22:56 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2018-09-24 03:22:56 DTC Client socket (21) | Creating socket. | 2018-09-24 03:22:56 DTC Client socket (21) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:22:56 SC Data - All Services | Connected to server. | 2018-09-24 03:22:56 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:56 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:56 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:56 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:56 SC Data - All Services | Received logon response. | 2018-09-24 03:22:56 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:56 DTC Client socket (21) | Socket gracefully closed by remote side. | 2018-09-24 03:22:56 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:56 DTC Client socket (21) | Received socket Close event. | 2018-09-24 03:22:56 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:56 DTC Client socket (21) | Initiating close of socket by core. | 2018-09-24 03:22:56 DTC Client socket (21) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:56 DTC Client socket (21) | Closed. | 2018-09-24 03:22:56 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:56 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:56 SC Data - All Services | Using username 0 | 2018-09-24 03:22:58 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-24 03:22:58 DTC Client socket (22) | Creating socket. | 2018-09-24 03:22:58 DTC Client socket (22) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:22:58 SC Data - All Services | Connected to server. | 2018-09-24 03:22:59 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:22:59 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:22:59 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:22:59 SC Data - All Services | Sending logon request message. | 2018-09-24 03:22:59 DTC Client socket (22) | Socket gracefully closed by remote side. | 2018-09-24 03:22:59 SC Data - All Services | Received logon response. | 2018-09-24 03:22:59 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:22:59 DTC Client socket (22) | Received socket Close event. | 2018-09-24 03:22:59 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:22:59 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:22:59 DTC Client socket (22) | Initiating close of socket by core. | 2018-09-24 03:22:59 DTC Client socket (22) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:22:59 DTC Client socket (22) | Closed. | 2018-09-24 03:22:59 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:22:59 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:22:59 SC Data - All Services | Using username 1 | 2018-09-24 03:23:01 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2018-09-24 03:23:01 DTC Client socket (23) | Creating socket. | 2018-09-24 03:23:01 DTC Client socket (23) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:23:01 SC Data - All Services | Connected to server. | 2018-09-24 03:23:01 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:01 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:01 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:02 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:02 SC Data - All Services | Received logon response. | 2018-09-24 03:23:02 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:02 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:02 DTC Client socket (23) | Socket gracefully closed by remote side. | 2018-09-24 03:23:02 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:02 DTC Client socket (23) | Received socket Close event. | 2018-09-24 03:23:02 DTC Client socket (23) | Initiating close of socket by core. | 2018-09-24 03:23:02 DTC Client socket (23) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:02 DTC Client socket (23) | Closed. | 2018-09-24 03:23:02 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:02 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:02 SC Data - All Services | Using username 0 | 2018-09-24 03:23:04 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-24 03:23:04 DTC Client socket (24) | Creating socket. | 2018-09-24 03:23:04 DTC Client socket (24) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:23:04 SC Data - All Services | Connected to server. | 2018-09-24 03:23:04 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:04 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:04 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:04 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:04 DTC Client socket (24) | Received socket Close event. | 2018-09-24 03:23:04 DTC Client socket (24) | Socket gracefully closed by remote side. | 2018-09-24 03:23:04 DTC Client socket (24) | Initiating close of socket by core. | 2018-09-24 03:23:04 DTC Client socket (24) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:04 DTC Client socket (24) | Closed. | 2018-09-24 03:23:04 SC Data - All Services | Received logon response. | 2018-09-24 03:23:04 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:04 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:04 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:04 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:04 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:04 SC Data - All Services | Using username 1 | 2018-09-24 03:23:06 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2018-09-24 03:23:06 DTC Client socket (25) | Creating socket. | 2018-09-24 03:23:06 DTC Client socket (25) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:23:06 SC Data - All Services | Connected to server. | 2018-09-24 03:23:07 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:07 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:07 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:07 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:07 SC Data - All Services | Received logon response. | 2018-09-24 03:23:07 DTC Client socket (25) | Socket gracefully closed by remote side. | 2018-09-24 03:23:07 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:07 DTC Client socket (25) | Received socket Close event. | 2018-09-24 03:23:07 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:07 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:07 DTC Client socket (25) | Initiating close of socket by core. | 2018-09-24 03:23:07 DTC Client socket (25) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:07 DTC Client socket (25) | Closed. | 2018-09-24 03:23:07 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:07 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:07 SC Data - All Services | Using username 0 | 2018-09-24 03:23:09 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2018-09-24 03:23:09 DTC Client socket (26) | Creating socket. | 2018-09-24 03:23:09 DTC Client socket (26) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:23:09 SC Data - All Services | Connected to server. | 2018-09-24 03:23:09 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:09 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:09 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:10 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:10 DTC Client socket (26) | Socket gracefully closed by remote side. | 2018-09-24 03:23:10 SC Data - All Services | Received logon response. | 2018-09-24 03:23:10 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:10 DTC Client socket (26) | Received socket Close event. | 2018-09-24 03:23:10 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:10 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:10 DTC Client socket (26) | Initiating close of socket by core. | 2018-09-24 03:23:10 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:10 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:10 DTC Client socket (26) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:10 DTC Client socket (26) | Closed. | 2018-09-24 03:23:10 SC Data - All Services | Using username 1 | 2018-09-24 03:23:12 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2018-09-24 03:23:12 DTC Client socket (27) | Creating socket. | 2018-09-24 03:23:12 DTC Client socket (27) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:23:12 SC Data - All Services | Connected to server. | 2018-09-24 03:23:12 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:12 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:12 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:12 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:12 DTC Client socket (27) | Socket gracefully closed by remote side. | 2018-09-24 03:23:12 DTC Client socket (27) | Received socket Close event. | 2018-09-24 03:23:12 SC Data - All Services | Received logon response. | 2018-09-24 03:23:12 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:12 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:12 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:12 DTC Client socket (27) | Initiating close of socket by core. | 2018-09-24 03:23:12 DTC Client socket (27) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:12 DTC Client socket (27) | Closed. | 2018-09-24 03:23:12 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:12 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:12 SC Data - All Services | Using username 0 | 2018-09-24 03:23:14 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-24 03:23:14 DTC Client socket (28) | Creating socket. | 2018-09-24 03:23:14 DTC Client socket (28) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:23:14 SC Data - All Services | Connected to server. | 2018-09-24 03:23:15 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:15 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:15 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:15 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:15 SC Data - All Services | Received logon response. | 2018-09-24 03:23:15 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:15 DTC Client socket (28) | Socket gracefully closed by remote side. | 2018-09-24 03:23:15 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:15 DTC Client socket (28) | Received socket Close event. | 2018-09-24 03:23:15 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:15 DTC Client socket (28) | Initiating close of socket by core. | 2018-09-24 03:23:15 DTC Client socket (28) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:15 DTC Client socket (28) | Closed. | 2018-09-24 03:23:15 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:15 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:15 HD Request # 3 | Downloading Intraday chart data for DYZ18 to the file DYZ18.scid. Service: eurex | 2018-09-24 03:23:16 HD Request # 3 | Download start date-time: 2018-09-24 02:23:39.000 | 2018-09-24 03:23:16 HD Request # 3 | Using server: ds7.sierracharts.com port 10149 | 2018-09-24 03:23:16 Socket (29) | Creating socket. | 2018-09-24 03:23:16 Socket (29) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:23:16 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:16 HD Request # 3 | Sending historical data logon request message. | 2018-09-24 03:23:16 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-09-24 02:23:39. Record interval: 0. Symbol: DYZ18 | 2018-09-24 03:23:17 HD Request # 3 | Decompressing data. | 2018-09-24 03:23:17 HD Request # 3 | Receiving Intraday data for DYZ18 starting at 2018-09-24 02:23:39 | 2018-09-24 03:23:17 HD Request # 3 | Timestamp of first Intraday data file record written: 2018-09-24 02:23:41 | 2018-09-24 03:23:17 Socket (29) | Initiating close of socket by core. | 2018-09-24 03:23:17 Socket (29) | Shutdown started. Waiting for graceful close. | 2018-09-24 03:23:17 Historical data download thread signaled to stop. | 2018-09-24 03:23:17 HD Request # 3 | Received 4645 records from 2018-09-24 02:23:39 to 2018-09-24 03:23:13 (59.6 minutes) and wrote 4641 records for DYZ18 | 2018-09-24 03:23:17 HD Request # 3 | Completion time: 2s | 2018-09-24 03:23:17 HD Request # 3 | Intraday data download complete for DYZ18. Unique request ID: 1 | 2018-09-24 03:23:17 Removed historical data download ID 1 | 2018-09-24 03:23:17 Real-time Intraday chart data file updates started for DYZ18 | 2018-09-24 03:23:17 Intraday chart data file opened for DYZ18 | 2018-09-24 03:23:17 Delaying start of download for NQZ18 | 2018-09-24 03:23:17 SC Data - All Services | Using username 1 | 2018-09-24 03:23:17 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2018-09-24 03:23:17 DTC Client socket (30) | Creating socket. | 2018-09-24 03:23:17 DTC Client socket (30) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:23:17 Socket (29) | Socket gracefully closed by remote side. | 2018-09-24 03:23:17 Socket (29) | Closed. | 2018-09-24 03:23:17 Chart #17 has tagged chart #4 for full recalculation. Chartbook: algo1_FDAX.Cht | 2018-09-24 03:23:17 SC Data - All Services | Connected to server. | 2018-09-24 03:23:17 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:17 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:17 DYZ18 [CBV] [M] Flex Renko 10-2-2 #4 | Performing a full recalculation because it has been tagged. Chartbook: algo1_FDAX.Cht | 2018-09-24 03:23:18 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:19 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:19 SC Data - All Services | Received logon response. | 2018-09-24 03:23:20 DTC Client socket (30) | Socket gracefully closed by remote side. | 2018-09-24 03:23:20 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:20 DTC Client socket (30) | Received socket Close event. | 2018-09-24 03:23:20 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:20 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:20 DTC Client socket (30) | Initiating close of socket by core. | 2018-09-24 03:23:20 DTC Client socket (30) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:20 DTC Client socket (30) | Closed. | 2018-09-24 03:23:20 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:20 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:20 SC Data - All Services | Using username 0 | 2018-09-24 03:23:22 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2018-09-24 03:23:22 DTC Client socket (31) | Creating socket. | 2018-09-24 03:23:22 DTC Client socket (31) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:23:22 SC Data - All Services | Connected to server. | 2018-09-24 03:23:22 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:22 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:22 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:22 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:22 SC Data - All Services | Received logon response. | 2018-09-24 03:23:22 DTC Client socket (31) | Socket gracefully closed by remote side. | 2018-09-24 03:23:22 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:22 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:22 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:22 DTC Client socket (31) | Received socket Close event. | 2018-09-24 03:23:22 DTC Client socket (31) | Initiating close of socket by core. | 2018-09-24 03:23:22 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:22 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:22 DTC Client socket (31) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:22 DTC Client socket (31) | Closed. | 2018-09-24 03:23:22 SC Data - All Services | Using username 1 | 2018-09-24 03:23:24 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2018-09-24 03:23:24 DTC Client socket (32) | Creating socket. | 2018-09-24 03:23:24 DTC Client socket (32) | Connecting to IP: 8.18.161.133. | 2018-09-24 03:23:24 SC Data - All Services | Connected to server. | 2018-09-24 03:23:24 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:24 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:24 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:25 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:25 DTC Client socket (32) | Received socket Close event. | 2018-09-24 03:23:25 DTC Client socket (32) | Initiating close of socket by core. | 2018-09-24 03:23:25 DTC Client socket (32) | Socket gracefully closed by remote side. | 2018-09-24 03:23:25 SC Data - All Services | Received logon response. | 2018-09-24 03:23:25 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:25 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:25 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:25 DTC Client socket (32) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:25 DTC Client socket (32) | Closed. | 2018-09-24 03:23:25 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:25 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:25 SC Data - All Services | Using username 0 | 2018-09-24 03:23:27 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2018-09-24 03:23:27 DTC Client socket (33) | Creating socket. | 2018-09-24 03:23:27 DTC Client socket (33) | Connecting to IP: 8.18.161.135. | 2018-09-24 03:23:27 SC Data - All Services | Connected to server. | 2018-09-24 03:23:27 SC Data - All Services | Starting socket receive thread. | 2018-09-24 03:23:27 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-24 03:23:27 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-24 03:23:27 SC Data - All Services | Sending logon request message. | 2018-09-24 03:23:27 SC Data - All Services | Received logon response. | 2018-09-24 03:23:28 SC Data - All Services | Server Name: SC Real-Time Server. | 2018-09-24 03:23:28 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-24 03:23:28 SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-09-24 03:23:28 DTC Client socket (33) | Socket gracefully closed by remote side. | 2018-09-24 03:23:28 DTC Client socket (33) | Received socket Close event. | 2018-09-24 03:23:28 DTC Client socket (33) | Initiating close of socket by core. | 2018-09-24 03:23:28 DTC Client socket (33) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-24 03:23:28 DTC Client socket (33) | Closed. | 2018-09-24 03:23:28 SC Data - All Services | Disconnected from the server. | 2018-09-24 03:23:28 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-09-24 03:23:28 |
[2018-09-24 08:41:25] |
Just to provide a bit more information, I have logged into my broker account with both the first and second instances
[2018-09-24 09:22:19] |
You have many instances of Sierra Chart on a system and two of them are using the two real-time connections you have paid for. You are running into this error with a third.
[2018-09-24 10:07:20] |
Got it. There was an instance that I didn't realise was connected. Is there a setting to enable an instance to connect to SC data without automatically connecting to real-time data if there happens to be a real-time connection free?
[2018-09-24 18:53:38] |
You can disable the Allow Support for Sierra Chart Data Feeds option as explained here: Sierra Chart Exchange Data Feed: Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
