Date/Time: Fri, 10 May 2024 08:49:31 +0000
Change Bitmex DTC to Bitmex API
View Count: 898
[2018-09-24 03:35:13] |
User651753 - Posts: 77 |
I am trying to use BITMEX API but it is still showing my account via DTC ( have 2 accounts) but I only want to use the API I have even created a new folder install, however, it when I login the DTC of my first account is the only one that shows. do I need to remove all DTC from all account to be able to use API? |
[2018-09-24 04:00:00] |
If you are referring to what you see on the BitMex website related to Sierra Chart and the DTC integration, contact BitMex about this.
[2018-09-24 07:26:14] |
nope , I am trying to use the API however your software is still using the DTC . is there a way in setting to not use DTC ?
[2018-09-24 19:14:39] |
You just need to follow through the step-by-step instructions here: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
