Date/Time: Thu, 02 May 2024 11:59:56 +0000
Add another sysmbol NYSE TICK
View Count: 754
[2018-09-23 21:28:42] |
Infinite - Posts: 134 |
When I open NYSE TICK in a chart alone it functions properly and barely uses any CPU power. But, When I ADD ANOTHER SYMBOL(nyse tick) onto an existing chart(S&P e-mini) my CPU power increases to over 25%. I like using it on an existing chart because it is neat and convenient and my pointer lines up with current candle being printed. Any tricks to lowering CPU usage when I "add another symbol" to my existing chart? |
[2018-09-23 22:02:23] |
We would not expect this. We see you are running an older version of Sierra Chart. And the Add Additional Symbol study is a relatively new study and you really need to run the current version to have all of the improvements and issues resolved related to it. Update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-23 22:19:46] |
Excellent. New version downloaded and now CPU usage is 3% !!!
[2018-09-25 17:03:19] |
actually during the normal trading day the CPU usage went back up to over 25%, and all of that is SC.
[2018-09-25 17:19:28] |
Technically this does not make sense, and we notice 0% CPU usage when using this very same configuration with the Add Additional Symbol study. The cause must be related to something else. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-25 17:19:37
[2018-09-25 21:27:18] |
OK thanks, When I remove the Add Another Symbol the CPU usage goes down to 3-5%. I will get to the bottom of this eventually.
