Date/Time: Thu, 02 May 2024 18:30:05 +0000
Chart windows mixed up in chartbooks
View Count: 826
[2018-09-23 16:54:47] |
User97684 - Posts: 136 |
Hi, I have 3 chart books, and after pressing the CW button it always used to reveal the charts that i had in each book. 3 days ago i gave names to the charts in Chartbook 1, using the Title bar Name under Advanced Settings 2 in Chart Settings. Then I noticed that now when pressing the CW button in the Chartbooks 2 and 3, the chart windows names are all mixed up and are 22, mixture of all sorts, whereas they used to be 6 or 7 and dedicate to the chart books i.e. ES in the ES chartbook , and now 6E charts are showing the in the ES chart book. http://www.sierrachart.com/image.php?Image=1537721636263.png |
3_chartbooks_with_mixed_up_chart_windows.png / V - Attached On 2018-09-23 16:54:35 UTC - Size: 130.34 KB - 236 views |
[2018-09-23 21:05:22] |
The only potential area of confusion could be that you may have set a chart to be always visible across Chartbooks: Window and CW Menus: Window Always Visible (Window) Otherwise, what you are describing is not even possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-23 21:05:47
