Date/Time: Fri, 13 Nov 2026 18:06:03 +0000
Alert before order entry level
View Count: 1337
| [2018-09-23 14:49:00] |
| User734334 - Posts: 6 |
Good evening, is it possible to have a table like I have in ninjatrader? - see attached file. This table shows me planed entry order level and how many pips left to reach the order in differen symbols. When left 15 pips to reach the entry level program sends me an email with alert, that the entry is comming. Is this possible in sierrachart? Thank you very much for answer. |
| [2018-09-23 23:44:40] |
Yes it is through the Study Summary but you have to create the necessary studies to do the calculations you want to get the required values. Refer to: Study Summary Window We are not sure how those values are getting calculated. And certainly you can set up an alert condition on a particular study to get an email message. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-09-24 07:57:44] |
Thank you, I dont know what studie to use. I only need to see what distance in pips is the actual price from my limit orders. In ninjatrader table I see my levels and what distance in pips is the actual price from my levels in different markets. When the price is near my level I go to trade the market. Thanks. Date Time Of Last Edit: 2018-09-24 11:21:07
| [2018-09-24 19:08:31] |
Okay a custom study would have to be developed to do this. Sierra Chart does not provide anything like this now. Unless you have a study which is currently showing the level, then you could use the Study Subgraphs Difference Study: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-24 19:08:56
| [2018-09-25 05:07:17] |
Good morning, I have an other question. I am not able to set the market profile. On attached screenshot you can see volume profiles with two market areas. In both areas is approximately the same volume but in the second area are the volume bars twice wider. I would like to have the volume bars of the same width in case of the same volume. Is this possible? Thanks. |
| [2018-09-25 16:09:09] |
| John - SC Support - Posts: 48526 |
Yes, you can do this. You need to set the Input for Volume Profile Bars Length Relative to All Visible Profiles to Yes. You will find the documentation here: Volume By Price Study: Volume Profile Bars Length Relative to All Visible Profiles
| [2018-09-25 18:17:53] |
I have done it, but there is no change - see attached file.
| [2018-09-25 21:48:41] |
Ok. We are looking into this.
| [2018-10-07 15:04:47] |
Good evening, is there something new in this problem? |
