Date/Time: Mon, 13 May 2024 00:56:26 +0000
How to show the child window menu (hyphen, square, cross)
View Count: 766
[2018-09-23 10:13:23] |
User849476 - Posts: 17 |
Hi Team, Could you please help me to solve this issue ? one of my chartbook has the right window menu hidden as you can see in the screenshot 1 I would like to make it available as you can see in screenshot 2. Could you please tell me how i can do that ? Thanks and regards, |
Screenshot 1.png / V - Attached On 2018-09-23 10:12:21 UTC - Size: 78.14 KB - 245 views screenshot 2.png / V - Attached On 2018-09-23 10:12:29 UTC - Size: 27.42 KB - 207 views |
[2018-09-23 21:28:04] |
It looks like you have hidden both the Title bar and Menu of a detached chart? Right-click along the Region Data Line at the top of that chart and select Show Menu. And then you can enable the title bar from the Chart menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-24 19:02:25] |
John - SC Support - Posts: 31555 |
You need to select the specific chart and then select Chart >> Show Title Bar. Here is the documentation: Chart Menu: Show Title Bar (Chart menu)
