Date/Time: Sat, 04 May 2024 08:52:52 +0000
[User Discussion] - Red study label and exclamation point
View Count: 639
[2018-09-20 22:52:55] |
GiantAvocado - Posts: 67 |
What does this label mean, see attached picture? I have searched and can't find an answer. These two studies reference the same spreadsheet and the programming disappeared while I was working on another study, same chart. I used the .scss backup to restore but not sure what the error is.
Attachment Deleted. red label study region.png / V - Attached On 2018-09-20 22:51:36 UTC - Size: 5.58 KB - 278 views |
[2018-09-21 18:35:41] |
Also getting the red pennant in the cells; I once had found this but cannot find anything on these obvious warnings now?
[2018-09-21 19:43:56] |
That is an Alert that has gone True associated with a study in that particular Chart Region. You will find information on Alerts starting here: Study/Chart Alerts And Scanning: General Information
[2018-09-21 19:47:08] |
These two studies reference the same spreadsheet and the programming disappeared while I was working on another study, same chart. This has been resolved. Update to the current version:Software Download: Fast Update Also refer to our prior response as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-21 19:48:01
