Date/Time: Thu, 02 May 2024 08:18:27 +0000
Updated to Newest SC version. Problem with market depth
View Count: 458
[2018-09-20 16:52:32] |
Luke - Posts: 142 |
I just updated to the newest version, the option to select maximum depth levels displayed isn't there anymore. In the older version there was the option to chose market depth levels displayed in the global chart DOM settings, I had this set to 1 level. This option isn't available in the new version. How can I set Market Depth Level to 1 now? I do not want to have Depth of 10 in the DOM. Also the chart grid looks different after the update. width 1 and line style Dot, same setting, but the dots seem to be further apart... Date Time Of Last Edit: 2018-09-20 17:05:17
[2018-09-20 19:31:50] |
John - SC Support - Posts: 31293 |
You can control the Market Depth levels on the Chart >> Chart Settings >> Advanced Settings 3 tab (it was moved in a recent release). Refer to the following: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) With regards to the Grid, yes, it has changed as the underlying code for graphics is being worked on. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-20 19:37:29
