Date/Time: Thu, 02 May 2024 08:06:48 +0000
Prfile for BTC BSTMP
View Count: 537
[2018-09-20 14:38:54] |
User59157 - Posts: 5 |
Hi I am having big problems with a profile chart for BTC. SC seems to really dislike a profile chart for bit coin. the profile chart is so slow it is unusable. in fact it slows up the whole running of SC in general so it too is unusable. when I close the TPO chart SC returns to normal running. I have no idea what is wrong. i'd appreciate your help thank you. Daniel |
[2018-09-20 19:44:42] |
The first thing to check is your setting for Letter/Block Price Increment in Ticks for the TPO chart. If this is left at the default of 2, it will run incredibly slow, as there are simply too many blocks being calculated/displayed and then trying to be updated. For BTC, it should probably be a value of about 100. Also refer to: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
