Date/Time: Sun, 05 May 2024 10:23:21 +0000
Scanning of options
View Count: 1264
[2013-10-25 02:10:36] |
1. No, this is not supported. We recommend having a look at either the Barchart Data service or the IQ Feed data service: http://www.sierrachart.com/index.php?l=doc/data.php Using their market data feeds, you should be able to do some custom programming and accomplish this. 2. You could write a function that does this in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
