Date/Time: Wed, 08 May 2024 07:53:05 +0000
[Programming Help] - Chart Pattern Scan/Alert
View Count: 1596
[2018-09-19 15:23:11] |
User379468 - Posts: 508 |
Is it possible somehow in SC to create an automatic scan or alert to notify of a chart pattern across different instruments, like a head and shoulders?
[2018-09-24 05:01:51] |
Any idea?
[2019-02-22 01:09:49] |
User948528 - Posts: 108 |
Anyone know if this is possible or has done it?
[2019-02-22 11:31:15] |
Ackin - Posts: 1865 |
Would you like only HaS?
has pat.png / V - Attached On 2019-02-22 11:31:07 UTC - Size: 77.52 KB - 458 views |
[2019-02-22 22:46:57] |
Thank you for your help. Ideally I would like H&S, Rectangle, Right Angle Triangles, and small+tight Flags/Pennants. With a clear horizontal boundary line breaking being the signal trigger. Date Time Of Last Edit: 2019-09-12 06:23:38
[2019-09-12 06:23:56] |
Ackin/anyone, could you help with this?
[2019-09-12 06:55:17] |
Hi, I have several patterns, I would probably find some flags somewhere in my free samples. But It would be better if you defined exactly what you need. Paterns can look differently. Something else is a triangle (two crossing-trend-lines) and something else is HaS. This is already a very specific area and I need more information to do this. When you sign up for my forum, we can do a discussion there with pictures of what is possible and what is not. Then I could make the solution you need. https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2019-09-12 07:25:41
