Date/Time: Sat, 27 Apr 2024 20:14:54 +0000
More than one Chartbook
View Count: 547
[2018-09-17 09:10:57] |
nicktrader - Posts: 665 |
I am using more than one Chartbook and I do have 5 monitors in use. I'd like to use one monitor for observation purposes only. If I switch to a different chb the charts on the "observation monitor" vanish. Is there a way to see the charts on the "observation monitor" permament dispite of switching of the chb or is the only way a second instance? |
[2018-09-17 19:24:20] |
You can make a chart window always visible. This is explained here: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-17 19:24:30
[2018-09-17 19:24:41] |
Refer to this setting: Window and CW Menus: Window Always Visible (Window)
