Date/Time: Sun, 19 May 2024 01:42:21 +0000
Spreadsheets : filling formula down
View Count: 1192
[2018-09-15 06:21:44] |
User556932 - Posts: 31 |
Hi SC Support a) I am trying to set up an auto-trade function to initially back-test using the Spreadsheets. b) I am entering Buy Entry formula into cell K3 My question is: c) how can I have the formula fill the rest of the column K automatically? i.e. copy to K4, K5, K6....etc. For context, I have seen some posts on You-Tube where upon entering formula in K3, it fills down automatically, but I cannot locate how to do this Thanks in advance Richard |
[2018-09-15 09:31:37] |
There is nothing special to do. This happens automatically. Are you using the Spreadsheet System for Trading study? Refer to: Spreadsheet Systems, Alerts and Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
