Date/Time: Wed, 13 May 2026 09:53:32 +0000
[User Discussion] - Woodies CCI Trend does not display colors
View Count: 2598
[2013-10-24 10:14:34]
User53496 - Posts: 34
Suddenly I cannot see the colors for the bars (red and blue) in the Woodies CCI panel, even thought they are defined properly in an imported chartbook. see attachments
attachmentsierra1.bmp - Attached On 2013-10-24 10:14:10 UTC - Size: 1.37 MB - 922 views
attachmentbars not shown.bmp - Attached On 2013-10-24 10:14:20 UTC - Size: 960.05 KB - 786 views
attachmentbars shown.bmp - Attached On 2013-10-24 10:14:26 UTC - Size: 960.05 KB - 924 views
[2013-10-24 11:58:20]
Bedhog - Posts: 184
Take a look at the study settings on the first tab "Settings and Inputs".
The Chart Region Default=2 and the Value Format Default = .01
[2013-10-24 12:00:33]
this is the way it is defined, but it still doesnt work\
[2013-10-24 12:03:02]
Bedhog - Posts: 184
How about the symbol session times? Try setting the time on that chart to 00:00 23:59 and then unchecking Evening Session.
[2013-10-24 12:13:52]
no evening session, start time is 00:00 end 23:59:59 still not working..
[2013-10-24 13:47:26]
Bedhog - Posts: 184
Test a new chart...
File; Find Symbol
Enter or locate your symbol
Open Intraday Chart
Analysis; Woodies for Range Charts
If everything shows up on that chart correctly, you could consider this as a starting point.
[2013-10-24 14:10:07]
hi, i took a new chart and added study "Woodies CCI Trend" in region 2. the region is empty and there is nothing in it. when i added "Woodies CCI Trend - Old" study, i see the bars, but their color is different than what i am used to ( there are no neutral bars for the beginning of a trend etc.) see attachment
attachmenterr2.bmp - Attached On 2013-10-24 14:10:04 UTC - Size: 1.06 MB - 1226 views
[2013-10-24 15:07:50]
Bedhog - Posts: 184
I've never tried to use it standalone.
Do you have the Woodies for Range Charts study collection?
http://www.sierrachart.com/index.php?l=doc/AdditionalFiles.php
Save the file into your ..\sc\data folder and reference the previous post for how to load it.
imagewoodies-for-range-charts.study-collection.jpg / V - Attached On 2013-10-24 15:07:33 UTC - Size: 102.85 KB - 665 views
[2013-10-24 15:11:50]
ok thanks. i will reply further tomorrow as it EOD for me..
[2013-10-24 15:36:05]
Bedhog - Posts: 184
...then I take the teal colored woodies chart and minimize it. Then overlay the cci14 and cci6 values on the charts I really want to watch.
[2013-10-24 16:10:40]
Problem solved. I used the "Woodies CCI Trend - Old" study and played with the values till i got it right. thanks for all your help :)
