Date/Time: Mon, 06 May 2024 14:10:20 +0000
Adding filled background to text on indicator
View Count: 689
[2018-09-14 16:29:22] |
User563418 - Posts: 6 |
Hello, On the Ask Volume Bid Volume Difference Text indicator is there a way i can add a fill behind it? Basically like a box behind the text with a fill color. Is there a way to do this? or even if you know what lines of code would need to be added to the indicator code? Thanks, SD |
[2018-09-14 19:16:38] |
The closest that is available is this draw style: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle_CustomValueAtYWithBorder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
