Date/Time: Tue, 07 May 2024 09:30:08 +0000
Data feed
View Count: 567
[2018-09-14 18:11:44] |
First refer to this help topic: Differences With Data and Chart Bars Between Services / Connections / Chart Types If you still cannot resolve the issue, then yes would be best to use the Sierra Chart Exchange Data Feed if that is what they are using: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
