Date/Time: Sun, 05 May 2024 14:23:22 +0000
Tool configs
View Count: 574
[2018-09-14 16:19:29] |
____ - Posts: 8 |
I have two differens TC for Volume by price study attached to my control bar. Is it possible to draw a profile and jump between say TC1 and TC2 just by clicking at the buttons in my control bar? TC1 a VP and TC2 is a DP. I know I had this before but cant remeber how I set that up. Thanks |
[2018-09-14 18:30:18] |
Yes, this is supported and here is the relevant documentation for this: http://www.sierrachart.com/index.php?page=doc/Tools.html#UsingMultipleDrawingToolConfigurations The documentation is somewhat out of date. There is no longer a Save As tab. You just need to select the configuration number on the first tab and use the Save button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-14 18:30:56
