Date/Time: Tue, 07 May 2024 12:15:58 +0000
Multi Bracket Order with 2 entry levels - is this possible?
View Count: 647
[2018-09-14 04:39:20] |
User180747 - Posts: 2 |
Hi, As per the Bracket Order documentation you can link via OCO groups - specific Target & Stoploss orders together no problem. Easy as the original order has the same entry level. My enquiry is if it's possible to link 2 OCO group orders but with different entry levels? Example: Buy 1 Contract at entry price of 1000.00 - Stoploss@990.00 and target@1030.00 - move StpLoss to Breakeven @1010.00 Buy 1 more contract at Entry Price of 1010.00 - stopLoss@1000.00 and target@1030.00 - move StpLoss to Breakeven @1020.00 Is it possible to combine these 2 OCO's brackets together into 1 sent order via chart trader? (you could say this is like a scale-IN order in a way) Thank you for your time on this. Regards Andrew |
[2018-09-14 18:48:00] |
These need to be sent as separate orders.
