Date/Time: Sun, 28 Apr 2024 23:11:08 +0000
Session Settings
View Count: 607
[2018-09-13 17:35:21] |
User104352 - Posts: 10 |
I have problem with the session settings. I enter cash session time in the chart settings window and after hitting the ok button chart shows the right session time but when i switch charts or restart my computer chart does not save this setting. can you help me? how can i set up a chart that shows only data from day session for example. Thank you! |
[2018-09-13 18:07:24] |
Did you save that chart as part of a Chartbook and reopen the Chartbook? Also refer to: Global Symbol Settings: Setting of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
