Date/Time: Fri, 03 May 2024 09:23:33 +0000
Candlestick Numbers Bars
View Count: 4507
[2013-10-24 02:02:09] |
User49270 - Posts: 48 |
Hi, Is there any way to overlay the numbers bars over a candlestick chart so that your able to see the candlestick with the bid ask breakdown. Thank you |
[2013-10-24 02:06:46] |
ganz - Posts: 1048 |
User49270 yes, it is possible https://www.bigmiketrading.com/sierra-chart/29007-ofa-sierra-chart.html http://s23.postimg.org/8614mbqe3/ofa_4.jpg |
[2013-10-24 21:11:53] |
How about a chart like this: http://www.sierrachart.com/image.php?l=1382649089414.png You can do this by setting the Open and Close Marker Style input to Open to Close Boxes with the Numbers Bars study. And set Place Boxes In to Column 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-11 09:36:01] |
binaryduke - Posts: 360 |
Use Study/Price Overlay to overlay the main price graph onto your chart displaying Numbers Bars and play with your Candlestick Width in graphics settings for the chart.
