Date/Time: Sun, 19 May 2024 00:53:32 +0000
Bitmex: How do you set leverage in Sierra Charts for orders going to Bitmex?
View Count: 1417
[2018-09-13 12:37:14] |
4646ed - Posts: 230 |
Bitmex: How do you set leverage in Sierra Charts for orders going to Bitmex? If you set it on their webtrader it doesn't translate to orders sent by sierra charts. Is there a workaround?
[2018-09-13 20:39:24] |
User911911 - Posts: 2 |
Hello, Bitmex auto adjust your leverage with your position. So its not on Sierra chart as I know.
Date Time Of Last Edit: 2018-09-13 20:40:40
[2018-12-15 17:43:57] |
User350717 - Posts: 10 |
Does this mean you can just send an order from Sierra that is larger than your balance? Like if I have 1BTC on Bitmex, then through Sierra I can place an order for 10BTC, and it will automatically use my whole balance and set leverage to 10x? |
[2018-12-15 23:19:15] |
Newer versions of Sierra Chart do support setting the BitMex leverage but the leverage is set on Positions and not orders. In regards to post #3 that is a question for BitMex. We do not know the answer for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
