Date/Time: Sat, 18 May 2024 23:30:18 +0000
Software update affecting spreadsheet system for trading
View Count: 662
[2018-09-12 20:35:10] |
User739131 - Posts: 27 |
Hello, I recently updated my sierra charts software and noticed that it affected my spreadsheet system for trading. I think what happened was that in the new version the color bar based on alert had some changes made to it which added some new ID's to it. That in turn through off the code of my spreadsheet. Just wanted to let you know in case someone else has this issue. Thanks, MJ |
[2018-09-13 04:49:18] |
Yes the Color Bar Based on Alert Condition study does have new Subgraphs. Make sure they are set to not output to a Spreadsheet. Refer to the information here about this: Using the Spreadsheet Study: Solving Study Not Displaying On Spreadsheet Sheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
