Date/Time: Sat, 04 May 2024 17:54:51 +0000
Free trial extension for topstepstrader combine
View Count: 929
[2018-09-12 20:00:03] |
User827943 - Posts: 5 |
Hello I just paid for topsteptrader combine and I heard that one month of free trial is provided for topsteptrader combine users. My username at topsteptrader combine is S1Sep13111632 I am looking forward to get my account trial extended to a month. Thanks in advance |
[2018-09-12 21:12:26] |
I was little confused before. I will be using this account for topsteptrader combine. If there's any other trials you guys can cancel it. Please activate this account so that I can get started with combine. Thanks! |
[2018-09-12 21:27:18] |
Sierra Chart - Max - Posts: 5605 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you can request another trial, up to a total of 30 days assuming you have not already received those trial days previously. After this you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
[2018-09-12 21:40:18] |
I was promised a month of free trial for topstep trader combine. Do you guys mine extending my trial to a month right now? So that I dont have to worry about it 15days from now on?
[2018-09-19 14:15:24] |
my account still needs to be extended for topstep combine. Please do so asps. Thanks!
[2018-09-20 06:52:01] |
This is done.
